Sign in to follow this
chris321
Help Needed
i have 1997 toyota celica and the engine management light has come on and the engine has started reving up and down
when the car is standing still and just ticking over does anyone have any idea what this could be cheers
Share this post
Link to post
Hi chris it is possibly your egr valve or air flow meter or possibly the lambda sensor which is giving you trouble you can clean out agr with carb cleaner as for airflow meter you will have to buy a new one or a used one. the oxygen sensor can be checked with anyone who has obd software most local garages can do this they will also be able to check airflow meter at a cost of about £30 to £40
Share this post
Link to post
hi mate
check with: MAF sensor and clean throttle and check with all sparks. the problem must be there.
cheers/Igor
Share this post
Link to post
Firstly check for any leaks in the inlet system and also the engine coolant temp sensor electrical connections are clean and sound.:)
Share this post
Link to post
a fault code scan may show up whats wrong. do it yourself its easy enough .
Share this post
Link to post
JOIN TE1 AND E1 IN THE DIAGNOSTICS PORT NEAR THE Battery , THEN SIT IN THE CAR AND COUNT THE DASH LIGHT FLASHES --- SPACE - = 31 ---- SPACE ---- = 44, CODES REPEAT
Share this post
Link to post
May sound silly, but i had similar thing a while back and it was the alternator so the engine was fluctuating up/down ..
Share this post
Link to post
the problem is we have not got any feedback from the author.
the subject outcome has many reasons and we hahve no idea what we can start from !!!
cheers/Igor
Share this post
Link to post
