Avensis
bigjagjim
Hi all,i have a 2005 avensis d4d and wondered if someone could tell me whats involved in removing the gearbox and how to go about it.I need to change the clutch
Hi mate, I have attached a couple of pdf files that should tell you all you need to know. You will need to download the free Adobe reader software first from the net to open the file if you don't already have it.
It's a big expensive job to tackle so if you have never done a front wheel drive clutch before on a big car like an Avensis then get a reliable garage to do it for you using genuine Toyota or top quality replacement parts.
Regards and good luck, Pete.:thumbsup:.
MANUAL TRANSMISSION & TRANSAXLE.pdf
CLUTCH.pdf
Hi mate, I have attached a couple of pdf files that should tell you all you need to know. You will need to download the free Adobe reader softwear first from the net to open the file if you don't already have it.
Thanks Pete
Looking at that and the main agents say it can be done in 6.5 hours its a big job!
It was what i was thinking a big pain!
Ive the clutch from toyota with the new flywheel and will give it a good look over in the morning
Thanks for the pdf files thats what i was after
Jim
Thanks Pete
Jim
The job will have taken me 12hours without a ramp or a pit,just axel stands. The old track rod ends replaced and the antiroll bar links.What a pig of a job but the old dual mass clutch had done 180k and from what others say on here it must be something of a record given the amount of problems others have had!Dont know why castle nuts and split pins are used on a car this young on track rods,the new rod ends have nylocks.
Jim
Thanks Pete
Jim
Jim
Well done Jim!! I bet you're glad that ones over mate, takes me back to the days when I had to do them sort of jobs on the side to make ends meet .... well i'm glad them days are over, just think how much money you have saved and knowing the job has been done right as well. I'm always happy to help out where i can so glad the pdf files were of help.:thumbsup:.
Best regards Pete.
Hi t-spiritpete, I've to replace my 2004 Avensis saloon 1.6 petrol clutch & my wifes 2002 Corolla 1.4 VVTI 4 door clutch - expensive after Christmas. Just wondering if these downloads are basically the same for the 1.6 Avensis & 1.4 Corolla ? Is there anything to watch out for while c/o the job ? Thanks in advance.
