Fitting Alloys In Place Of Steels
nig.xl
Not at home so can't check at the moment. Does anyone know if the steel nuts can be used on standard Toyota alloys or are they tapered.
I know I should really of checked before buying the new alloys.
The alloy wheel nuts have a square shoulder and fit flat / flush to the wheel, steel wheels are usually tapered, it is very important to check what type you have otherwise you will be watching a wheel overtake you........Not good :lol:
Kingo :thumbsup:
I never realised how many shapes of wheel nut exist when I bought alloys for the first time. Since then I've bought several sets of alloys for the 2 RAVs and each set of nuts is different. As Parts-King says, the wrong nuts can be dangerous - I know! I had fitted the wrong nuts to a set of MAK Mirrors I had and stopped at a layby on a dual carriageway to investigate the knocking noise - the front wheel off-side was held on by 1 nut....the rest had fallen off :eek: :eek: :eek:
Lesson learnt!!!
I can rig you up with some wheel nuts for alloys if you need some.
Pm sent :thumbsup:
