Sign in to follow this
sponge55
Matrix Flush (Heating)
I know there are many threads on this already but i am having great difficulty in removing the two pipes in the engine bay that lead to the matrix itself.
i have been using a pair of pliers to open up the clip and pulled the pipe at the same time but i'm either not pulling with enough force or i'm doing it all wrong??
can someone shed some light on an easier or a correct way to remove these two pipes please?
thanks
Share this post
Link to post
Use your pliers to remove the clips full away from bulkhead. And pull. If he pipes are really tight introduce a bit of heat to soften them up. Either a heat gun or some near boiling water works.
Share this post
Link to post
thanks, i will give that a try later today
Share this post
Link to post
I agree with the advice from Clawliger on the heat, hot water is probably enough. When I did mine (method here) I had warmed the car up previously to help a bit, of course you need to take great care and release the pressure in the system first (detail in the linked post). Good luck with it!
Share this post
Link to post
didnt have time to do it today. weather got to minus temp again so will give it a go later on in the week!!
Share this post
Link to post
i have given it another go but i am still unable to remove the pipes.
how much will it cost for a garage to do it so i know whether i'm getting ripped off when calling up for quotes?
or if there is anyone in the manchester area wanting to make some spare cash for xmas, get in touch! =)
Share this post
Link to post
They are a little tough to get off if they have been off since the car was made, with the engine warm I slipped the clips down the pipes with the pliers, then used a flat headed screw driver to carefully prise the rubber from the metal pipes and then they slipped off ok.
Share this post
Link to post
just run your car for a while and then pull the clips back, twist the pipes slightly to break any seal thet may have and then with a good pull they should come off
Share this post
Link to post
twisting sounds like a good idea... attempt no 3 at some point this week. thanks guys!
Share this post
Link to post
