Well I Can't See One!...
Mistermena
Can anyone tell me if my 2007 Avensis D-4D T-180 D-CAT has a hydraulic clutch? I can't seem to find a reservoir for it anywhere? I can se the brake fluid and water top up points, but not one for the power steering or clutch!… :help2:
Hello, I'm 100% sure your car has a hydraulic clutch.:yes:.
Regards Pete.
Regards Pete.
Hi Pete,
Many thanks for the responce. Any idea where the clutch reservoir is? :blink:
Regards Pete.
Hi Pete,
It is the composite tpe with brakes fluid - in other words the same brake fluid serves both systems.
cheers/Igor
....Any idea where the clutch reservoir is? :blink:
You may find that the clutch shares the same reservoir :huh:
Thanks guys for the reply's... I started to wonder if that was the case! Cheers :toast:
