Over Sprung Landcruiser
benhowison
hay i live in out back nsw austraila iv got a 93 hzj75 landcruiser ute i drive in deep mud when i rains but i find as it starts to dry my springs start to get stuck when im in the wheel tracks just woundering if any one on here has done a spring over conversion or got any better ideas on how to fix the problem would like to see some pics of sprung over landcruisers to see how high thay are im hoping i can do the gob and not make it stupedly high thanks ben.
Ben, your best solution would be to fit a new set of 2Tonne springs to it.This should give you a tads more ground clearance without taking it over the top. The one I had seen done belonged to a property at Bollon and it had a good ground clearance however it was a back breaker to ride in.
Cheers mate and I hope this is of some help. Greg.
