Carina E Door Lock
Plingy63
Folks,
I'm after a replacement spring that's part of the drivers door lock assembly. My local dealership can only sell me the entire mechanism (at £241 + VAT)...which is a tad more than I wanted to pay for a spring (see attached image).
If anyone knows of where I can get one of these springs, I'd be grateful.
Cheers.. Paul
Try sending your requirements through here:
http://www.247spares.co.uk/toyota/
I got 3 replies for a part that I was after in 24hrs ;)
  • 4 years later...
Many thanks for posting the picture of the spring, now I know exactly what I am looking for as I just got myself a second hand Carina with exactly the same fault.
Hi there,
First of all, thanks again for posting that picture, I also found that spring inside my drivers door. I am in the process of removing the lock assembly now. However, could anyone tell me a bit more about where that spring belongs exactly? That would make the detective work a bit easier.
Cheers,
Allard from Stavanger, Norway
Exactly what I need to know too, cant get the door lock out, cant find a replacement spring
aaaaaaaaaaahhhhhh help
I had the exact same problem, I found a suitable spring in one of the hundreds of boxes/jars etc..of bike/car bits I've hoarded over the last twenty odd years. Here's a picture of my mechanism. (Front passenger door, 1995 CarinaE)
Hope this helps. Don't hesitate to ask for more info. I did a full report of this repair when I did it on the CarinaE Owners Club but when I tried to retreive it for you I found the site had closed down ! My estate door is now playing up,I'll have to investigate. :(
...Just to add to what I just said,
I think the spring may have been out of a drum brake?
A trip to any well stocked car accessory store should have what you need. :thumbsup:
BTW: Shouldn't this be in the Carina section ?
:unsure:
Excellent, Thanks
Now if only I could disconnect the linkage from the lock to the handle !!! to get the mechanism out !!
:thumbsup: No problem, Pleased I could help.
Bought my CarinaE from StHelens (Your neck of the woods I notice.)
& were I was born. :D
Thats exactly where I live !!
Eccleston if you know it ...
