Had Car Rolling Roaded
ses6jwg
I think I will check the TYPHOON, as my wiring on the MAF extension may not be making the best connections, I might also try using a smaller gauge wire.
you need to use the exact same gauge wire mate, if you used a smaller cable it may increase electrical resistance and the maf might not receive or send the correct signal
I used thicker gauge wire.
what gauge is the standard wiring?
