Rear Wiper Not Operating
Nav786
Hi, i am a little confused as my rear wiper is not operating the front one is working fine but the rear one is faulty when i activate it i can hear a little tic tic sound from the motor of the viper but it does not operate what could possibly be the problem ???
I would guess that the motor is working as you mentioned that you hear a tic-tic sound. I would guess that the viper arm is not fastened to the vipermotoraxle correctly. If I remember correctly iy is some splines on the axletap where the viper is mounted. I believe those are too worn either on the axle or the viper.
