D R L
Grosvnr
post-72738-0-43662600-1300738217_thumb.jive recently fitted Ring Aurua Day Time Running Lights to my Aygo Blue ,they look stuning,but couldnt fit them where i wanted to because of the lack of space,
post-72738-0-87695500-1300738244_thumb.j
I thought that after market DRL's had to be mounted futher apart than you have mounted yours
Apart from that they look good!
hello grosvnr,
in Germany the drls have to be mounted more apart, too.
By the way, what colour is your car? It isn´t mystic blue, is it?
Hi, you haven`t replied yet. Today I learnt that in Germany the DRLs
must be 60 cm apart and 25 cm above the ground (minimum measurements)
I love the colour of your car - it looks great! Is it slate blue met
allic or what else?
Finally I figured it out! You got the C a y m a n Blue, but where is the violet-green-ish hue? Yep, you can see it only in bright, sunny daylight and this I didn`t know.
So you also got a magic/mystic blue colour like I do :yes:
It`s great colours they developped, changing with the light of the day.
The U K legal req state, DRL should be fitted so their outer edges are no more than 400mm from theouter edge of th vehicle, height above the ground must be a minimum of 250mm and a maximum of 1500mm ,ECE reg 48 ,& mounted symmetrically in pairs & the same hight from the road & same distance from the sides of the vehicle,the lamps must be positioned to ensure the light emitted does not dazzle other road users,we have recently changed our car for an aygo GO ! with aircon in chilli red,& will attempt to refit my DRL`s to my current http://www.toyotaownersclub.com/forums/public/style_emoticons/default/thumbsup.gifaygo,asap.
