Keyless Go System
igormus
Hi Guys
Mine have just served one year and eight months. Is that normal? What are your observations?
Please share comments.
Cheers/Igor
Hi Guys
Cheers/Igor
As part of the 2nd year service, my dealer replaced the Battery in both fobs.
One year and eight months does seem a bit short though.
Hi Guys
Cheers/Igor
ok -- what is normal life time , then taking into account either original or branded???
it 's interesting to hear from you
Cheers/Igor
Igor,
I did change mine after about 2 years, but it didn't really need it.
I assume you are talking about the "keyless entry" one? i.e. you have a "start" button in your RAV and don't insert a key to start?
Those will probably be a bit heavier on Battery use. In and around the vehicle they are in regular communication with the car, unlike the standard remote entry ones, where it is just one transmission to lock/unlock.
:thumbsup:
Igor,
Those will probably be a bit heavier on battery use. In and around the vehicle they are in regular communication with the car, unlike the standard remote entry ones, where it is just one transmission to lock/unlock.
:thumbsup:
Sorry, for may be not good translation :D -- sure I ve got only start button and have just changed a tablet inside No 1632. A warning signal has notified me when driven from work to garage. I ve measured the DC voltage and it was 2.93 V --the new once measured was 3.35 V. Cheers/Igor
Does your keyless go system equipped with door handle with induction button?
If it is, the Battery can used at least 2 years.
If it is, the battery can used at least 2 years.
hello mate
thanks for asking -- yes the door handle has induction button as build in.
it was a first alert on the clock -- the engine could still be started etc --- i ve just changed it to be assured.
It is clear confirmed its life time is around 2 years.
Cheers Guys
hello mate
Cheers Guys
Yes, I remember the lifetime of Battery is 2 years.
Does your smartkey an original one or add by yourself?
hello mate
Cheers Guys
hello again
for sure it was 2nd tablet after original one. i ve asked the cost of it from MrT and have lost the last hair having known the price -- that was a reason of purchasing the same characteristiics tablet but OEM.
Cheers/Igor
