Windscreen Washer Pump Failure?
quilmore
hi
I can't get the washers to work on the windscreen
the one at the back works
I've umplugged the tubbing going to the bonnet and it's not getting any preasure when attempted
where is the windscreen washer pump? can't find it
would you know what could it be? it's a 1.6l petrol corolla verso from 2005
hi
hi mate
firstly you should fine the plastic tank with flash water -- the cylinder type pump or even two are mounted in the tank. They are so small to disclose under the bonnet. Check with fuses first. In the worst case when pump is burnt our -- no way to rewind it but only change. Cheers/Igor
