1996 4.1 Water In Drivers Side Sill
bonwitco
Hi
I have a 1996 RAV4 LWB right-hand-drive and have noticed a "slushing" sound from the front passenger side door sill. Removed the plastic panel over the relays and noticed a 1/2inch tube running down from what I think is the sunroof. It is rattling at the bottom but I cannot see where it ends up? I also tried removing the inner wing plastic guard hoping to see the end of the tube but can see nothing?
I leave for a long run to the south of ireland on Sunday and would need to fix this before I leave.
Could someone please tell me how to get the water out of the sill. What is wrong with this drain and thirdly. How do I fix it?
Thanks in advance of anyone's help!!!
Hi and welcome to the forum
There is a water run going from the sunroof area to the nearside wing... which may be blocked.
My own expereince has been the front scren seal leaking and allowing water in but the water ends up in the front passenger footwell.
in yourcase. there should be a draqin which is maybe blocked. Compressed air maybe help down the drain
