T Sport Vac Hose Sizes?
b1gpkr001
Hi
Any one know what size the vac hoses are on the t sport? Want to replace them.
Measure the ID (internal diameter) as if you look online most will be measured with ID
Do you know what the id should be?
Haven't got my calipers here to measure the hose properly as I'm off work.
if you are going to upgrade to silicone tubing then use ID of 3mm, this will fit all the vacuum ports on the engine.
If you go to shows this year you can buy a 3m length of any colour for £3 and this will cover all your needs.
I did mine in red
