Alloy Wheels Offset?
The Law
Hi, I am looking to replace my wheels on a 2001 corolla, and seen some alloys that are 14"X6" with a 25 offset, is this offset too small and rub? I will probably will be fitting 185 60 14 size tyres. Also is the stud diameter 100?
Many Thanks.
Isn't the off set around 35????
I am no expert but think it might be too small
The smaller the offset number the more "space" you get between the spoke and the hub. So if the standard offset is 35 then 25 will push the wheel out by 10mm on each corner.
P.S The stud pattern is 4x100
