Sign in to follow this
massoh
Toyota Super Long Life Coolant
Hello,
I will need your help for two themes
for buying Toyota Super long Life Coolant (Pink)to be shipped to Milton Keynes - UK as i stay abroad and the Toyota Local Dealer had changed the coolant to my 2007 Avensis 1.6L when it reached 40000KM/ 5years age!!...and replace it with a local 33% dilluted coolant... I Need 2 Lites only because already brought from Greece a pack 5 Litres and the manual says i need 5.8 - 6.1 L
another help if there is not a 2 litres pack availability,,, need help to know:
can i add Distilled water to complete the measure with the pack i have 5L from the Toyota SLLC ?
do i have to make a flush? and do i realy have to empty both the radiator & motor block from the coolant?
sorry for such questions i do not have someone to trust to tell me the right moves.
thanks a lot and best regards.
hossam nabil
Share this post
Link to post
Hi
The TSLLC only comes in 5 litre packs. You should not add any water to it, you will need another 5 litre pack to top it up
You will never get all of the old fluid out of the engine block, just empty it as best as you can, no need for any types of flush unless you have had any form of contamination
Kingo :thumbsup:
Share this post
Link to post
Any suggestions as to where to buy Toyota Super long Life Coolant?
Share this post
Link to post
You can buy it from ourselves, just call our parts department on 01244 821031
Kingo :thumbsup:
Share this post
Link to post
You can buy this in 1lite tubs now from your local Toyota centre
Share this post
Link to post
Loading...
