Rear Lights
badsanta
Hi.
I am having a problem with my drivers side rear light indicator. It wont light up. I have checked the bulb and still nothing.
Brakes lights, Indicators and fogs all working both sides. Just the drivers side light not lighting up. ( Light work fine on other side)
Nothing indicating a problem on the dash.
I have traced the wires back but nothing seems to be causing an issue.
Any ideas would help
have you tried swaping bulbs over to see if the fault is the bulb
