3sfe Upgrades
russell st
does anyone know what I can do to a 3sfe engine in an 87 celica to get more speed and to make it last longer?
Not much. Performance comes at a cost, that is the shorter life of the engine. You'd be better off running the 3SFE into the ground and starting to build up a decent 3SGTE. The turbo units come stock on the ST185 @ 225hp and respond very well to tuning. Then again you have to weigh up the cost of a GTE against the total value of you car. If you really want to get that little bit more power from the FE then go for the cheaper mods like a pod filter, performance lead set, extractors etc. This will cause it to wear out faster though.
I'm new to this Toyota Engine's stuff but... From what you say it sounds like your implying that the 3S-FE is somewhat shortlived...all things relative what's the average life of one? I'm having a few starting problems with mine at the minute and no-one reading Toyota Family seems to be able to shed some light on my embarressing predicament.
btw this is in a carina II not a Celica, sorry guy's :help:
Nah the FE is a good engine, I had one in a ST182 Celica but as far as tuning goes you could pour hundreds into it and still be blitzed by a GT-Four with a tweak of a boost controller. Don't get me wrong, my 3S-FE had 150km on it and the only thing i did to the engine was plugs, oil and filters. I had no problems at all with it. Starting is usually ignition so check that the coil is giving you a decent spark or if you have a leak through a HT lead. Toyota engines do last though, over 200km on my 3S-GTE and no worries.
isn't the 3sgte an all wheel drive engine... and if so how much would I have to do for an 87 celica st?
I have a 3S-GE motor in my 87 toyota celcia gt-s... no matter what i do.try with this motor... it will still run a civic home. as for your 3s-fe... best bet is to probably just find another toyota celica in that year, or like he said... get a 3s-gte motor and put it in it... as soon as i get some compression readings on my motor, i will start rebuilding it. it has over 300,000 miles on it without an overhaul... and it still will walk a civic home... shame shame shame :ffs:
  • 15 years later...
Hi, I have a 97 Liteace Noah with a 3SFE/4spd auto. No rocket ship of course, but want to get the best/most out of the motor within reason. It's done almost 325000kms / goes ok for what it is. Done the k&n pod filter install & I think it goes a bit better, especially from midrange upwards. Recently had the cambelt, water pump etc & valve stem seals done. What's a set of performance ignition leads & maybe some extractors worth, would it make much difference?
Just found it looks like you're not NZ based.
Thanks anyhoo
Edited by Tom Helmore
I live outside of the UK & had a price query
