Waterpump
illgryphon
Hey just a quick one, I need a new waterpump and have found one on eBay. I was wondering though if i am right in thinking the waterpump is the same for pfl/fl/comp?
Regards, Chris
Hey just a quick one, I need a new waterpump and have found one on ebay. I was wondering though if i am right in thinking the waterpump is the same for pfl/fl/comp?
Regards, Chris
Don't tell me your water pump has now gone?
Have a look carefully at the waterpump, toyota have changed the design and the flange and seal system is totally different on the new one.
I bought a replacement from toyota as mine started to leak, the new one needed the flange bolts cutting down.
Regards, Chris
its been leaking slightly, not badly but enough to notice and annoy me.
I might just confirm with fensport and get one off them if the design has changed, hopefully lee knows how to do cutting work when fitting the pump lol
Hi, just to confirm toyota have changed the housing as i fitted a new 1 from Mr T & yes had to cut 1 bolt down.
Have a check of the fensport one and see if it has the new seal, if it doesn't I would get the OEM one, it is only £13 more
