My Corolla T Sport Is Overheating And Only Blowing Cold Air... Please
Micallef
orite everybody just purchased a 02 corolla T sport this afternoon. i drove it back with no problems at all (didnt have the heaters on)
this evening i was driving it and realised i had no warm air coming through the heaters just cold/luke warm. also the car started to overheat then just dropped back down again to the middle by its self. i had a similar problem on my old fiesta and it turned out to be an air block could it be this.
I checked the oil today and the cap and it was a nice golden colour so shouldn't be anything like the headgasket should it?
Thanks Ben
The Luke warm air is common problem, normally not a serious problem. Do a search on here and you'll find previous posts. I think its do with the matrix getting blocked?
The over heating maybe a faulty senor? Did it actually go up in the red part of the temp meter?
thanks bud. i did do a quick search pal.
should i try see if it is a block? do i take the cap off and run the engine for about 20 mins whilst topping up the coolant?
It goes about 1-2 bars down from the top overheating mark pal
Have a read of that mate.
http://www.toyotaownersclub.com/forums/index.php?showtopic=76133&st=0
Regarding the over heating am not sure and i wouldn't like to guess. Have you checked the coolant?
will double check it in the morning. can you check both coolant levels or just the white reserve one infront of the radiator?
just left it running for 20-30 mins with the cap off (the metal coolant cap to the left of the radiator) it still blows cold air but didnt overheat
coolant was quite low in the reserve, topped it up and left the cap of for 20-30mins. the two pipes that are next to each that go into the bulkhead one was hot one was luke warm is that normal? or should both of the pipes be hot?
after i did this i was getting a small bit of heat but mainly on the passenger side
Theres an airlock in the coolant system. U need to top it up and rebleed the system. Remember the heater dial needs to be on fully hot when you do this
HTH
HTH
Thanks pal how much would a garage normally charge to do this ?
...after i did this i was getting a small bit of heat but mainly on the passenger side
Sounds more like the heater matrix symptoms to me now than an airlock, but obviously worth checking that through.
http://www.toyotaown...opic=76133&st=0
etihad linked the main heater thread above - bit of a lengthy one but worth a read. The method I used in my previous CTS is described in this post, part of that thread.
seems to be getting warm air through now as i left it with the reserve cap of this morning. also it isnt overheating so hopefully it should be good
i don't no if the problems are related as i've started using my heating in the car the last few days (for the first time, baught the car 6months ago and never needed it) and mine seems really ****ty, like blowing really luke warm ****ty air on my in no particular rush
Well was fine earlier today. Then started doing same tonight over heating then dropping back to normal very quickly . And just blowing cold air again :(
well just had a family friend around. and he checked it all over and it looks like somebody has filled it up with something dodgy as it was just froffing out as we filled the tank up. he is coming back again tomorrow to bleed the whole system,
my heaters was fine and blowing warm but he said this crap whatevers in will be causing air locks
also the ps light just came on my dash. looked in the owners manual and is says take to a toyota garage. does the ps stand for power steering? if so what could have gone as my level looks ok
TSports have electric power steering, what level are you looking at?
Regards.
arr i thought i couldnt find anywhere. i was looking at my brake fluid level haha (was very dark)
so do they not need any fluid then? they all electric?
well managed to do change all the coolant, now the heaters and blowing luke warm then will just go hot as they should be then back to just warmish.
also it doesnt look like my engine is warming up 100 percent.
anyone got any idea's what it could be?
also he plugged the computer in and it came up with no faults.
also just took it for a drive along the bypass and back, noticed smoke coming from bonnet opened it up and the reserve coolant was way over full and leaking out of the top, think he has just over filled it by putting too much in the other coolant cap ( the silver one next to radiatior)
Need help please i hope i dont have an head gasket problem :(
