1Kz-Te Rpm Problem
Arjuna
Hi Everyone
My 1KZ-TE Auto does not rev more than 3000RPM. The ICU check bulb is on. I have checked the turbo and it is fine and Air filter is new. I am wondering whether this is the throttle or the pump... Can someone provide good info to fix this problem? How do I know which one to open up? Any help is appreciated.
Regards
Arjuna
If the check engine light is on, have you done a diagnostics check to see what codes are logged?
