Lc5 Suspension Problem
euclid
I have a recurring fault on the suspension management on my 03 LC5 - but it's done over 205,000 miles without a problem so I suppose I shouldn't complain. It cleared when they replaced the Battery, but now it's back. Apparently an electrical issue, nothing to do with the shocks, etc., but it feels like I have no suspension at all...
Main dealer will obviously charge a fortune to fix it (assuming it can be fixed), so can anyone recommend a good independent specialist Toyota repairer in the Oxfordshire or Shropshire areas?
Thanks,
Jon
Probably the height sensors at the rear wheels. You might get away with stripping and cleaning them, but probably need replacing.
Sorry - don't knwo any specialists in that area.
Thanks for the input. It DID seem to be the rear wheels at fault.
It has to be the rear wheels - there's no height adjustment on the front wheels!
  • 11 years later...
Hi , I have a Lc5 07, the problem I have is that the rear suspension is always set on high , I can lower it but it only stays down for a couple of minutes before returning to high mode ! Any ideas, thanks
