P0402 Error Code Thrown Up, Egr?
TAF
Hi guys, ive got a 03reg 1.6 Corolla and im getting the engine light come on now and then... its only showing p0402 as the error, something to do with the egr??
Not sure what that is or where its located if anyone can help?!!?!...
Engine light only comes on when im doing long journeys at steady 60/70 speed :-S
What engine do you have? Petrol or diesel?
If its a 1.6 vvti T3 as in his signiture ;) and has an EGR valve its gunna be a petrol engine.
so on that note you more than likely just need to give it a clean and you will be all good again.
Thanks im on my mobile so cant see any sig.
Diesels have egr valves, vvti engines dont have egr valves as the ecu uses the vvti as a egr valve.
