Yaris Central Locking Units - Actuator Problem.
Tommygunn
It would seem I now have a problem with two doors of my 2003 Yaris D4D, the front left and right rear.
I suspected that it must be a problem with the actuator on each lock unit when activating central locking.
I removed the lock/CL unit from the back right door and removed the actuator from its mount. I connected 5V and then 12V and I got nothing so I reckon that cheap, Scalectrix motor they use must be knackered.
Therefore, are the actuators standard, at least from one door to another in the same car?
Is that the part number shown in the photo below, if not do you know the part number?
Will I need to buy the whole lock unit or can I get the actuator on its own?
Are there any good online breakers that I could approach for this parts?
Thanks.
Tom.
