Compressor Gasket Replacement
Rolla_SR
Ok so the gasket for the supercharger oil is discontinued and as far as I'm aware can be made from some paper. Just wondering if anyone has a good template if not I will make one in the coming weeks for other to use.
Also what thickness of Gasket paper do I need?
I had the same problem. But just take the cover of the charger lid and use that as a template. I got 1.5mm gasket paper from eBay and as far as I'm aware in the gasket pack you get it's two gaskets. Have you taken the cover off yet? Mine was fine when I changed mine.
