Starlet Gt Turbo Re-Build
russeh123
my project car :D , a freinds car :P hes not very good with them thats where i come in usefull , im a mechanic in training and the more practice the better :) its a good car very clean .... look at the link and i will try to keep up to date :) but also any help would be soooo helpfull cheers , russell http://www.flickr.com/photos/73822431@N02/
well it was showing usual signs of the bottom end going so it was taken to the performance centre ( my garage ) and we knew at this point it was gonna get a good old going at so just cracked straight on and started the tear down .. engine out and stripped down took the sump and oil pick up off , the ends of the rods on one of number 1 piston and found this
post-116273-0-82414500-1325987664_thumb.
Pretty bad bearings. How is the shaft? How are the other bearings?
have not had the crank checked yet mate but as you go down from 1 to 4 they seen to get worse
post-116273-0-40110700-1326025463_thumb.
this is the 3rd set they were welded together on the shaft had to break them apart with a hammer and screwdriver the picture is not great but they are like paper thin and have a sort of lip all the way around each side and the oil holes are just not there any more
post-116273-0-80503600-1326025684_thumb.
heres just some general pictures got a bit snap happy with the camera :P
post-116273-0-50503200-1326025950_thumb.
engine bay shot :)
post-116273-0-65575400-1326025975_thumb.
post-116273-0-05070300-1326026010_thumb.
hks exhaust apparently it goes from the decat 2.5" down pipe through a sports cat and centre to a 3" at the back box bit
post-116273-0-69380000-1326026255_thumb.
post-116273-0-23488200-1326026093_thumb.
they guy that sold him the car said it had a greddy gearbox or something along those lines i really dont know how to tell any ideas guys ??
post-116273-0-27685700-1326026123_thumb.
it does have an exxedy clutch in it with is not old it was done just before he bought it
post-116273-0-90772900-1326026061_thumb.
the head witch was rebuilt about 1000 miles ago after the gasket went on the standard engine it now has a few goodies on it
engine when it came out
post-116273-0-37303700-1326026038_thumb.
  • 1 year later...
To do just a head gasket on one of these glanza. Where can I get the head torque specs from or is it same ads normal starlet 1.3. Any help would be great as have to do a head gasket on one soon?
