Car Starts Then Stalls! Arrrrgh!
Cherry Red Pocket Rocket
Every now and then, when I turn the ignition, my car will start and then stall immediately or a split second after. It doesn't do it regularly nor has any warning lights flashed up so its very, very hard to diagnose and !Removed! annoying!
On Christmas Eve it did this and I had to start it ten times before it finally started! Since then it was fine but did it again this morning! Must have turned the ignition fifteen times before it finally started.
Can anyone recommend possible causes and solutions please?
I suggest crankshaft sensor starting to fail...Replace.
At bottom of timing chain cover...
