Radio Removal - 2005 Corolla
Coriolis
Well I've looked online and can see how to remove my '05 Corolla's radio, but I've fallen at the first hurdle - apparently you should pull off the middle environmental control knob to reveal the screw underneath, but mine's not having any of that - it simply won't pull off, irrespective of the position it's in.
I haven't pulled TOO hard to be on the safe side, so perhaps it's just on real tight?
Or is this perhaps not necessary for each model?
My radio is model: 58816
I'll try again - in the video it's the knob removal at 51 seconds that's the problem.
What type of corolla do you have?
I start in the middle and when that comes out I undo the four screws.
I don't have the whole airco stuff though, depends on your type of corolla :)
regards,
Chris
It's the 2005 Corolla
1.4 VVT-i Colour Collection 5 door hatchback.
Just the same as mine then :)
You can follow that guide, but without the screw in the Airco ( If you don't have those buttons ) Just make sure you undo the four bolts in the next step or you will rip something!
regards,
Chris
