Alternata Removin Belt . Help
badboyrasta
Trying to replace thermo on sport corolla , 52 reg , and cant get the belt of rolla pully , wen I try its just turning the alternata
please make this easy lol
You mean you want to remove the drive belt?
A guide is being created on the other channel, here's a quick procedure of what to do to remove/change the belt.
This isn't 100% but should at least help
1) Draw a diagram of how the belt runs around each accessory
2) 19mm spanner + bar on the tensioner "nut"
3) Pull the spanner towards you to release the tensioner off the belt. You need to hold it there to keep it that way
4) Whilst holding the tensioner, flick the belt off the alternator and remove. 2nd person makes life a lot easier
5) Route new belt around all accessories as per your diagram starting at the back of the engine, make sure that the belt is properly in between the guides on all the pulley's
6) Release tension again using spanner + bar and put the new belt around the alternator pulley
7) Check that the belt is ran as per your diagram, is in between all the pulley guides and tight all the way around
Yes ok , wen I find the tensioner nut , thanks for the info , bud .
