Fuel Warning Light
daglocks
Hi, hope someone can help.
I was driving my 2008 hilux vigo when the fuel light came on.
I checked the filter, no water, and changed the element..
Put a meter on the float sensor and raised the float, sensor works.
I tried to re-set the light by disconnecting the sensor and re-connecting it with the ignition on/off but no luck.
I tried holding the odometer re-set while turning on the ignition, and got 15, then 1-9, which I believe is to re-set the timing belt light.
Car runs well, but I have the annoying light, any ideas?
Andrew
Andrew
Dealer reset only
It is not a dealer reset, not SST required.
The correct way is to disconnect the sensor on top of the housing, IG on and reconnect. This only works 1/2 the time. The way I do them is to add a very technical tap on the top of the sensor housing with the handle of a screwdriver! May seem rough but it has not failed me once and I've been doing ot since they came out! Have changed a few repeat offenders due to sticking floats.
