Toyota Fuel Injection Cleaner Additive
gizmo999
Has anyone used this toyota product?
Do you just pour it into the fuel tank and let it run through while driving?
Any reply would be welcome.
Thanks.
post-75521-0-03029200-1330533064_thumb.j
What does it say on the bottle.should give directions of how much to put in your tank.
Yes when you done that just drive as would normaly.and let it do its stuff.
Thanks for your reply Acetip.
Unfortunately there are no directions on the bottle, as to use, only a multi-language pull-out warning label telling you how avoid contact with the stuff.
From what I have read in other forums, all that they contains is some sort of Kerosene (parafin). I do not know if that is any better than the cheaper non oem ones. I usually put 150ml of a similar product to a full tank of petrol. Don't even know if it works! It costs only 2-3 Euro per 300ml bottle.
Thanks.
Just bung it in a full tank of fuel :thumbsup:
Thanks.
Thanks for the confirmation Dave.
Will do!
Has anyone used this toyota product? Do you just pour it into the fuel tank and let it run through while driving? Any reply would be welcome. Thanks. post-75521-0-03029200-1330533064_thumb.j
Thanks for the confirmation Dave. Will do! Cheers
Not sure if`ll you`ll notice a difference especially if your fuel systems already pretty clean ;)
Its often cheap on eBay so hope you didn`t pay too much for it.
Yep, that's where I sourced it.
http://www.ebay.co.uk/itm/GENUINE-TOYOTA-FUEL-INJECTION-CLEANER-/251001646839?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a70dd2ef7
Thanks for your reply Rajiv.
