2007 1.4 D4D Gear Selector Problem
Gerryo
I've just bought this car, serviced and done the brakes front and back. The gear select to 1st and to second was stiff and I bought and replaced the cable. Still stiff so looking help/advice. Is this a common fault? 73k on the car.
Have you checked the box oil? Is it the correct grade? How;s the clutch?
The gearbox oil is good, the clutch good. Once in gear drives very well, it's the selection which is stiff ie when you move the gearstick with your hand it's feels stiff. I'm guessing this fault did the cable in so I need to get to the root cause. Thanks.
