A Mechanical Question Of Sorts.
Hassan_Chop
I have a 96 Corolla that needs a Timing belt.
1.6 liter engine 4A-FE
Question do I absolutely need a gear puller to take the cam sprocket out, or could I just pop it out gently with a crowbar?
Thanks in advance for any advise. :D
You shouldnt need a puller to take it off, but you shouldnt have to take it off anyway.
Thanks for your reply I was wrong I should have said the crankshaft pulley.
Thanks.
:D
