Wiper Blades Size ?
Tam Bam Magnet Dougal
i am after aero wipers for my 2000 w plate avensis gs...
asked somebody on the bay and he said 21" & 18" is this bout right as i am thinking 21" is a bit big
any help appreciated guys :P
those are the correct sizes
cool cheers matey ;)
a query or 2..will post them here rather than have more threads going...
headlights i got are them crappy black ones with the lines on the glass...i want the plain glass front ones...what these called ?
can the rubber stoppers on the tailgate (on the rear quarters and sides of tailgate) be bought ?
just thought of another 1....is there an upgrade for washer jets...as in spray kind ?
cheers peeps
i fitted my spray washers jets from my 206 gti..so thats solved that 1 lol
Just wondering if the 206 Washer Jets you've fitted are much better than the standard fit? Are they just a straight swap?
Cheers, Richard
Cheers, Richard
nah mate...had to cut the wee lug off them....but double sided tape to stick them down and a cable tie underneath cured that...loads better likes...spray instead of the jet...if your going for them...make sure they are phase 2...spray as opposed to the jet
cheers ;)
anybody any info on the tailgate stoppers/rubbers...this rattle is doin my t*** in likes :ffs:
are headlight bulbs h1 or h7 ?
looks like am gonna have to take out my headlights to fit hid`s..so just wanna make sure i get correct ones
cheers
cheers
I can't comment on the stoppers, only that I have the same occasional banging from the tailgate when going over bumps!
The headlight bulbs are H7, let me know how you get on with HIDs!
cheers
had a mate tucked away in the boot yesterday to find my banging lol
sure its coming from bulb holder on the drivers side...rattling...will ram a towel in it laterz when i go back out and see if it cures it
went and picked up a cheap set of headlights yesterday just so i can fit the hid`s then swap over headlights...
weather here has been brutal over past few days..will post back with pics when done ;)
Went To The Stealers Today And Ordered New Tailgate Rubbers...Nearly F****** Died When The Guy Said £36 For Them lol
Will Tackle My H.I.D`s Tomorrow...Weather Permitting
How are you getting on with the new tailgate rubbers, has it fixed the rattling problem?
yeah mate problem solved...even though i snapped a bolt puttin f****** rubber on :@
will get it drilled out and get new bolt though
what to do is jam it on 1 rubber at a time..i used a sock n fold it over...maybe 2/3 times...then hit sum bumps see if it solves it...this worked with me...so i knew it was rubbers that were worn...
