Corolla Wing Mirror Replacement
karstan
I've got a 53 plate Toyota Corolla T3 which has had the drivers side wing mirror damaged.
The mirror itself is shattered, the body coloured cover is in several bits and the wing mirror housing is also chipped. The plate that the mirror attaches to however is fine and the electrics all still work.
Does anyone know if it's possible to replace these parts without replacing the whole unit and if so how easy/difficult that might be.
Cheers
Hi, the easiest thing to do is just get the whole wing mirror from breakers yard, take off the plastic triangle inside the car remove the couple of nuts and disconnect the electrical harness clip thingy then put in new one. there pretty cheap so no need to fiddle around with broken parts. there's prob a vid on youtube on it.
