Newbie With A Problem :-(
Ann Ward
hello everybody, this my first toyota 1993 3ltr td auto, kzn 130. ive had it a whole week and i have problems!! it came with a non working speedo so yesterday I took the dash apart after first replacing the sender on the transfer case....now i have no side lights or fog lamp.. the only fuse box i can see is under the bonnet behind the drivers side Battery, all fuses appear okay.
are there more fuses?
many thanks, Ann.
fog lights now working, they were wired into the idle up switch! now connected to the headlight circuit, still no side lights though, is there a circuit breaker somewhere?
Welcome in to the TOC Ann, have you checked the plug going to the side light switch ?
