Sign in to follow this
nedofwales
50000 Service Details
Hi
Anyone out there in Toyota land know what's involved in a 50,000mile service?
It's a 2008 D4D 5dr Avensis had a major service last year which equated to a 40,000 service (car's only done 28000)
My local dealer called last week and quoted me £99
It may be worth it as they've got a deal where if you keep the car serviced with them you get your MOT free.
Share this post
Link to post
Don't panic chaps found out what's involved in an intermediate service see the following
Free Visual Safety Report
Free Wash and Vac
Check all pedal(s) and component(s)
Check steering wheel
Check horn
Check washers
Check wipers
Check interior lights
Check exterior lights
Check warning lights
Inspect air conditioning filter - replace as necessary*
Check seat belts
Drain engine Oil
Replace Oil filter
Inspect air filters
Refill engine Oil
Check levels and refill as required
Inspect suspension
Inspect steering
Inspect tyres
Inspect wheels
Check and adjust tyre pressures
Inspect brake pads and discs
Torque tighten wheel nuts
Check radiator and condenser
Check belts
Check Battery
Recheck for fluid leaks- underside and engine bay
Recheck all levels
Reset service lights or monitor as required
*Additional charges apply if work is required
Share this post
Link to post
Free Wash and Vac
Check horn
Check washers
Check wipers
Check seat belts
Drain engine Oil
Replace Oil filter
Inspect air filters
Refill engine Oil
Inspect suspension
Inspect steering
Inspect tyres
Inspect wheels
Check belts
Check Battery
Recheck all levels
Share this post
Link to post
