Metal Engine Undertray 1998 Colorado
JabbaTheHutt
Anyone offer any hints where the hidden fastenings are that hold up the undertray that runs from the front bumper back to the engine just under the sump, I suppose you could call it a sump guard.
I have removed three bolts from the front by the bumper, two from the rear near the suspension but it is still retained by something, something that I am damned if I can see it. There are no more bolts visible from underneath but I can't shift the thing so there must be something else holding it somewhere.
Anyone here that has taken this thing off know the secret?
No worries found the blighters about half way back on each side deep in a hole that looks like it takes no part in retaining anything - only it does - bolt head is about 4 inches deep and the bolt was also damned tight.
