Dead Radio In Celica
davemid
After replacing the Battery in my 2002 Celica there is no power to the radio but everything else works ok.
I have tried the reset procedure as described in the manual ( insert ball-point pen into the hole in the radio facia) but nothing happens. Could the fuse have blown? Took fuse box cover off to check fuse but I am unable to decide which is the radio fuse. The imprint on the inside of the fuse box case shows which is the abs fuse, which are lighting fuses, etc but I cannot see the radio fuse location. Could somebody please tell me which it is or suggest any other reason why the radio doesn't work. I have disconnected the Battery several times in the past to recharge the previous Battery without encontering any problems with the radio
