Diesel Knock
5362ssrx3.0
Hi guys, My 1995 SSRX 3.0l and driving is fine it drives like a dream but on idle it has what sounds like bad diesel knock or a pinking noise which dissapears at 2000rpm. Any ideas?
Hello and welcome in to the TOC, is it an engine knock ?
Injectors ?
http://www.hiluxsurf.co.uk/showthread.php?t=76736&highlight=injector+knock
Possibly. I've been doing some reading and my viscous fan has a bit of movement, could this be the cause?
It's only doing it on idle once driving or over 2000rpm it purrs like a dream
Topic moved from New Members Introduction Forum to HiLux Forum
you have an overfueling effect due to bad performance of injectors (nozzle tips wear down)
have all injectors calibrated on the fuel stand and your dream will continue
:) regards / Igor
:) regards / Igor
I`m over the moon I came to the same conclusion Igor :cheers:
