Avensis 2L Td - Diesel Tank Is Leaking
gruby
hi there,
in need of a bit of help
toyota avensis reg 00, TD, 2L 198000miles and diesel tank started to leak
there is a visible rust at the back where the top and bottom halfs joined. I did not dare to check how big the hole is
not to make it bigger. I have to park the car "bottom up" and have less then 10L of fuel in.
mechanic said it has to replaced.
I just want to ask:
- no tools or "silicones" to repair it? but maybe if repaired - will fail NCT/MOT check...?
- has D4D version same fuel tank as TD (scrap yard option)?
thanks in advance
you may try to repair by Devcon A plastic steel putty (450 gr tins)
it might be sold on the market. but a good spot degrease must be reached.
regards / Igor
