Whlrling Noise
conker
Hello Forum members,
Since having a full service at Toyota on my 2008 Avensis 2.2 T Spirit they seems to be a short whirling noise, maybe fuel pump has appear, the noise was not present before the service! Is this noise common or do l need to take it back to the dealer?
Thank you for any advice regards this problem, or if its not?
Conker
Try taking the air filter from its housing box. The air feed into the box may be vibrating causing an annoying whirring sound.I The feed from the nearside wing is a slightly loose fit. Duck tape will sort it if this is the problem.
