Used Fuel Injectors D4D?
mladenpet
hello,
i have avensis d4d 2.0 with all 4 fuel injectors bad, whole body of injectors has gone bad. I have denso injectors not Bosch.
How and where do i get used fuel injectors? I don't need only part that can be changed but whole fuel injector that works, taken from car that was in a crash or something like that. Because 4 new injectors from toyota cost around 2.500e.
How can i find them and be sure that they are fully working? I saw few on eBay.co.uk but i am not completely sure if they work and i am not from UK.
Any info would be helpful, thank you.
Others can correct me if I'm wrong, but I believe that getting a set of injectors from a scrapyard etc would be possible, but they would have to be caliberated via software which can only happen at a good independent dealer or a main dealer only which will cost
unfortunately there isn't really a cheap fix as such
hello,
i have avensis d4d 2.0 with all 4 fuel injectors bad, whole body of injectors has gone bad. I have denso injectors not bosch.
How can i find them and be sure that they are fully working? I saw few on ebay.co.uk but i am not completely sure if they work and i am not from UK.
Hello mate,
I am led to believe one of the best companies in the UK to deal with are Feather Diesels Halifax and comes well recommended, I have no connection with this company. Maybe an email or phone call to them may point you in the right direction but as jas16 says they can only be fitted by a Toyota dealer or someone like Feather Diesels who have the equipment on site.
http://www.feather-diesel.co.uk/
Regards Pete.
Any of the Denso dealers will help, PF Jones in Manchester for instance. They have to be programmed to your car
Kingo :thumbsup:
Oh thanks for fast replays, this forum is really active :)
I sent emails to those companies.
feather-diesle says they are repairing broken injectors. My whole injector if flawed, not just the thing on the end, but the body and electronics of fuel injector.
My avensis works fine when started, but it won't start when its hot, i need to wait for 1h to cool down.
Did someone bought refurbished and used fuel injectors before?
  • 2 years later...
Hi I have a similar problem on a 04 verso 2.0 d4d does anyone know If secondhand injectors can be programmed into the ecu ?
PM your chassis number, as Toyota have started to offer reconditioned injectors so there may be a factory approved reconditioned injector available for your car.
Thanks Devon i have contacted feather and they only have a new injector listed for my registration model so I took it they didn't do a recon I will have to contact them and ask them wether secondhand can be programmed in I will ring round again in the morning cheers
Not sure where feather source their injectors from, but Toyota have introduced reconditioned exchange injectors on some models but I would need a chassis number to confirm if they offer the option on your car
Thanks mate I will pm you the chassis number in a bit 👍
  • 5 years later...
What's the estimated cost of replacing fuel injectors in an avensis d4d icon
Hi mladenret,
I was in a similar situation, needed 4 replacement denso injectors for my 2005 2.2 D4D Avensis.
I live near Boston in Lincolnshire. I was put in contact with:J Jon Pick, who is a Diesel fuel specialist who is also in Boston. Within a few days he sourced me 4 reconditioned denso injectors plus seals for my car.
I have contacted him to ask his permission to pass on his contact details.
Mobile number 07974 681667.
With the new injectors fitted my car runs like new. The price was about £800.00
I hope this helps if you haven't already fixed the problem.
Peter ling
