Sign in to follow this
Kryz Orlinski
Warranty Anything Missing? For £265
Product: Ultimate Warranty
Term: 36 months
Vehicle: TOYOTA AVENSIS
Premium: £264.55
Parts Covered
Please see your Policy Schedule for details of the maximum amounts that may be paid for each and any claim. These may be subject to lower limits as stated on these pages. All limits include VAT. There is no restriction to the number of claims you can make. This policy covers the following parts against mechanical breakdown as defined below.
Engine
The rocker assembly, including hydraulic followers, inlet and exhaust valves [not burnt valves], springs and guides, cylinder head [not cracks and de-coking], cylinder head gasket [except skim], push rods, camshaft and followers, timing gears and chains [excluding tensioner], Oil pump, pistons and rings, cylinder bores (excluding porous bores), con rods, gudgeon pins and bearings, crankshaft and bearings, inlet manifold, flywheel and ring gear. Timing belts are covered provided that the last due change of belt has taken place as specified by the manufacturer’s schedule [proof required].
Manual gearbox
Internal shafts, gears, synchromesh hubs, selectors, bearings and bushes and transfer gears.
Automatic gearbox Internal shafts, gears, clutches, brake bands, valve block, governor, Oil pump, bearings and bushes, servo, drive plate and transfer gears.
Torque converter Failure of any internal mechanical parts.
Continuously variable transmission CTX Internal clutches, planetary gears, reduction gears, shafts, variable pulleys, thrust link drives, internal seals, bushes and bearings.
Differential
Internal crown wheel and pinion, gears, shafts, bearings and bushes, thrust washers and spacers.
Clutch
Centre plate, pressure plate, release bearing, Oil contamination [centre plate only] and master and slave cylinders.
Front-wheel drive
Drive shafts, including constant velocity joints, universal joints and couplings [not gaiters].
Wheel bearings
Front and rear wheel bearings.
Propshaft
Universal joints and couplings.
Rear-wheel drive
Half shafts, rear-wheel external drive shafts, including constant velocity joints, universal joints and couplings [not gaiters].
Four-wheel drive
All four wheel drive components are covered if the extra premium has been paid [see Policy Schedule].
Fuel system [diesel and petrol] Carburettors, automatic choke, lift pump, mechanical or electrical fuel pumps and tank sender unit.
Fuel injection system
Throttle body, airflow meter, idle control valve, cold start valve, warm up regulator, overrun cut off valve, throttle potentiometer, fuel
accumulator, pressure regulator, map sensor [except injectors and heater plugs].
Engine cooling system
Radiator, Oil cooler, heater matrix, water pump, viscous fan coupling, thermostat and thermostat housing.
Air conditioning [factory fitted)
The air conditioning compressor unit is covered if you have paid the extra premium. [see Policy Schedule.]
Steering [including power assisted steering]
Steering rack and pinion [not gaiters], steering box, power steering rack and pump, power steering reservoir and idler box.
Turbo charger [factory fitted]
The turbo charger unit is covered only if agreed and if the extra premium has been paid. [see Policy Schedule.] ULTIMATE CAR WARRANTY POLICY
Front and rear suspension
Hydrolastic displacers and hydropneumatic spheres, coil springs, upper and lower wishbones and ball and swivel joints.
Brakes
Brake master cylinder, wheel cylinders, restrictor valve, brake calliper seals and servo
Anti locking brake system [ABS) [factory fitted) providing the additional premium has been paid the ABS modulator and sensors will be
covered. [see Policy Schedule].
Electrical system
Starter motor and solenoid, including pre-engagement mechanism and bendix drive, alternator/diode pack, coil voltage regulator,
window and sun roof motors, electric window switches, sunroof switch, centralised locking motors, heater fan motor, indicator flasher
relay, distributor, front and rear windscreen wiper and washer motors, electronic ignition amplifier, thermostatically-controlled radiator
fan motor, horn and multi-function stalk switch.
Engine management [ECU]
Engine electronic control unit.
Working materials
Oils, Oil filter and anti-freeze are covered only if it is essential to replace them because of the failure of a part which is covered under this policy.
Casings
If any of the covered parts fail and this damages the casing, it will also be covered.
Share this post
Link to post
I have posted many times on the value of off the peg warranties
You make your own mind up, BUT Iwould be worried about the very first paragraph,
What is the claim limit?
What are the lower limits?
Claims include VAT, that means the value of the claim is reduced by 20% in real terms
and the most important.............
This policy covers the following parts AGAINST MECHANICAL BREAKDOWN, rarely does anything MECHANICALLY BREAKDOWN, usually it wears and fails, this would NOT be covered
You pays your money and makes your choice............
Kingo :thumbsup:
Share this post
Link to post
Thank you for that. I did try and attached the "Full" policy. The max is the value of the car.
Good note on the MECHANICAL BREAKDOWN. I think they would say if the flywheel and clutch needed changing it was "wear and tear" not MECHANICAL BREAKDOWN
Share this post
Link to post
Mechanical breakdown will be described in the warranty policy, it will be along the lines of "sudden and without warning, failure or breakage" anything that is "noisy" like a wheel bearing will not be covered
What is the lower limit they describe? Most policies are up to the value of the car BUT certain items may have lower limits
You will find lots of items covered, however most of those items will rarely fail, you have to balance the good with the not so good :rolleyes:
Kingo :thumbsup:
Share this post
Link to post
Retail over £305 a set
Kingo :thumbsup:
Share this post
Link to post
Kingo :thumbsup:
This is so very true, Kingo! For example, if your water pump starts whining, everyone and his brother knows the bearing is going out. But many of these aftermarket warranty companies refuse to replace it until it actually breaks, i.e., quits pumping or leaks.
One glaring ommision I noticed is that the aircon compressor is covered, but not the evaporator or condenser? And only after you pay an extra premium? That's crazy. Compare this to what my Toyota extended warranty covers:
AIR CONDITIONING/HEATING
Air Conditioning Lines and Tubes; Air Conditioning Pressure Switches; Air Temperature Control Programmer; Blower Motor; Blower Motor Resistor; Compressor; Compressor Clutch Assembly; Compressor Pulley; Condenser; Condenser Fan and Motor; Evaporator; Evaporator Temperature Sensor; Expansion Valve; Heater Control Valve; Heater Core; Idler Pulley; Pressure Regulator Assembly; Receiver/Dryer; Schrader Valve; Seals and Gaskets; Cooler Control Switch; Cooler Unit; Damper Servo; Defroster Control Cable; Heater Control Head.
Share this post
Link to post
James, you have a Toyota extended warranty, this is NOT a Toyota policy but an off the peg warranty, and IMHO, not worth the paper they are written on
Kingo :thumbsup:
Share this post
Link to post
