4Zz-Fe With 1Zz-Fe Cams?
scott5
hi guys does anyone know if the cams from a 1zz will fit into a 4zz cylinder head? am planing on changing the crank pistons and rods and bearing to the 1zz-fe parts to make it a 1.8 and want to run high profile cams aswell??
i think ​the cams are the same mate... the main difference is in the crank-rods-pistons-inlet manifoil-trottlebody and injectors
Ive read some conflicting info on this stating the 3zz and 1zz cams are a different profile to the 4zz ones. However i havent seen ANY proof to back these claims up and i personally dont believe there is any difference at all, so im going to back you up :thumbsup:
A quick call to toyota to check would confirm this ;)
IIRC Madvinger did not change these in his 1zz conversion which started out as a 4zz. Hes making more power than the 1zz had on paper so it backs up that there not any different :)
Thanks for the reply guys, i think ill try get a cheap set of 1zz cams ans see if they fit first before splashing on the high profile ones :D
  • 7 years later...
Hi did you have any joy with the 1zz cam in the 4zz? Desperate to find out. Thanks
The OP hasn't visited the club since October 2012, so you may not receive a reply.
  • 2 years later...
