Sign in to follow this
T25-AVENSIS-D4D
P 0108,p 1251 Which Is The Exact Problem?
HELLO TO EVERYBODY!
I HAVE A AVENSIS T25 2.0 D4D
SOMETIMES CHECK ENGINE OCCURS WITH P 0108 + P 1251 CODE.
WHEN I ERASE THE CODES THE CAR IS OK.
DOES ANYBODY KNOWS THIS PROBLEM?
Share this post
Link to post
CAN SOMEBODY TELL ME WHICH PART OF THE CAR SEE FIRST?
I HAVE DONE SOME CHECKS!
I CAN SEE FROM THIS FORUM THIS IS A PROBLEM FOR MOST AVENSIS!
THANKS TO ALL!
Share this post
Link to post
Normally it is related to the turbo, sticking vanes is a common issues. Where did you get the fault codes read? Main dealer or independent?
Alex
Share this post
Link to post
Hello Awebb180!
I have a code reader.When i press the car with full load the P1251 occurs.Then i erase it.
So,i will disassemble the turbo to see inside exactly.
Thanks for the help!
Share this post
Link to post
in case this code is for vanes -- then check with hteir easy rotation on the pins/
besides -- check with vacuum tube hole as well
regards / Igor
Share this post
Link to post
