Sill Scuff Plates
Phil White
I have just fitted some Stainless Steel scuff plates to my 3 door Aygo and they do look nice.
A place in Leeds makes them and sells them on eBay for just under £20.00 so cost is reasonable too.
Here is a photo of the drivers side and a photo of my recently fitted rev counter too.
Which dash cover do you mean? If its the one above the radio its for the built in tomtom so folds down to how you see it.
Nice sills. I have a five door Aygo though - these are for the three door. Anyone know of sills for the five door 2012 Aygo?
Why don't you measure your sills to see if there is 700mm of straight sill and if there is i am sure they would fit.
Just gone out to do that and my Aygo has around 500mm of sill suitable for mounting a scuff plate :-(
Ahhh ok, why not try contacting that eBay seller to ask if some can be made to 500mm as i think the seller also makes them.
Ahhh ok, why not try contacting that ebay seller to ask if some can be made to 500mm as i think the seller also makes them.
Or why not buy the longer ones for the 3 door and carefully trim them down
Have contacted the seller to ask.
My DIY skills are pretty pathtic - would much rather buy the right size from somewhere. Might have to buy the official scuffs.
Thanks for your suggestions, guys.
They do look nice i suppose but don't cover as much of an area. If the cost was comparable to the stainless steel ones they would be worth buying but at over 40 quid it's just too much.
