P1155 Obd2 Code 2003 Rav 4 2 Litre Petrol
bitman
Just a couple pictures of the sensor removal when you get the P1155 error code on your OBD2 reader.
P1155 upper left; Toyota part# 89467-42020 / Denso part# 234-9028 / Walker part# 250-54003
Tools needed; gt85 (or what ever around), 12mm spanner, 22mm ring spanner and rubber hammer;
Release the 3 bolts and 1 nut carefully not to break them;
Take off the shield;
Remove the sensor with a 22mm ring spanner, if tight CAREFULLY use the rubber hammer;
When installing the new sensor, nut and bolts use copper crease so next time they come off easy.
Great job Bitman !
There's no need to whisper Bruno - it is indeed a GREAT JOB BITMAN :thumbsup:
Hi,just got the engine management light come up on my 2003 Rav 2.0 GX,checked and got this code p1155 and it lists it as air ratio sensor 1 is this the same as an oxygen sensor as i was told it was the sensor in the air box.would be grateful for any advice.
