Does Corolla T Sport Have Obdll Output Socket ?
borodaz
Hi Borodaz.
If your T Sport is OBDII compliant, you should find a socket in the left hand side of the drivers footwell. It should be a "D" shaped socket (just a smidgeon below the plastic dashy bit).
I believe they were standard from 2002 (ish) on petrol cars and from 2004(ish) for diesels (but I'm sure someone will correct me if I'm wrong).
If you do have the socket, then there are dongles that will connect to your phone/laptop.
Cheers
Rattus
