Corolla E10 14" Wheel
JingJangJong
Hi this is my first post so apologies if it is a daft one!
My elderly but beloved Corolla E10 was damaged in a crash a few weeks ago and I now need a replacement wheel. This is probably a bit of a daft question, but do I need to get a specific wheel or will any 14" wheel with four studs do?
Thanks in advance!
Thanks in advance!
I would get a 14" wheel that is same width,or close as you can put the same size tire on, but also look at the offset the ET number to be the same. Some older !Removed! and maybe some newer ones actually have the same stud pattern but are 4x114 and not 4x100.
Hope that helps.
Thanks in advance!
Hope that helps.
Cheers mate, that makes perfect sense, I'll keep an eye out at the local scrap yard for any c92 - 96 Corollas knocking about!
